Originally Posted by Manne
So.. aren´t you running summit shafts in the middle now?
I'm not running them now, I had to replace them with stock ones because they became so sloppy that they were about to fail. What's on my truck now is the stock middle shafts with RCM drive shaft coupler with 8 mm bore to match my LST XXL diffs.
The Traxxas middle CVDs would have been a very good option also, I just didn't think of it. The Kershaw dogbones with RCM drive cups (8mm bore) are on the way so I will try those. If it doesn't work out then it will be the Traxxas way.
