_dV
11.19.2010, 02:35 AM
Damn those axles are $
Where did you get the spacers?
LiqrSicc
LiqrSicc's Avatar
11.19.2010, 03:54 AM
nice job on the axles...
for the spur, if you really cant tighten it enough... unscrew the 3 screws that hold the top part of the tranny... and then grip the spur really tightly with your whole hand and then tighten the bolt...
Thanks bro. I pulled it apart yesterday and it looks like I smoked it!
Originally Posted by Gdot View Post
the savage has a slipper clutch? never used it. locked it when i opened the box.
Planning to do the same as soon as I get a new slipper
Spacers came from aluminumspacers.com
They have just about all the sizes you can think of. Pretty cheap too!
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
Axles
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Axles - 11.19.2010, 10:24 AM
Those axles look very much like the old "FireHammer" axles. Are those 8mm shafts? If they are the firehammer axles are probably about the same size and are a lot cheaper.
SUPERMAXX YOUR LIFE.
LiqrSicc
LiqrSicc's Avatar
11.19.2010, 10:44 AM
Jerry, I hope you're wrong just for what I went through to get these
But I hope you're right so everybody else can go the cheaper route!
I have no idea what the old firehammer axles look like. I googled it and the picture showed an axle which looked a lot longer than these and had a threaded tip, not to mention no hole for a pin to go through. Can you link me?
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
You correct.
JERRY2KONE
JERRY2KONE's Avatar
You correct. - 11.19.2010, 06:24 PM
No you are correct. I drilled a hole for the pin, and then cut off the threaded part of the stubshaft with my dremel tool. Then I installed a set of HPI 17mm adapters so they can push the Axial beadlock wheels. They work perfectly.
_dV
11.19.2010, 07:26 PM
The Flux dog bones have an 11mm ball. I don't think there is a detachable cup you can buy in that size?
Not sure
JERRY2KONE
JERRY2KONE's Avatar
Not sure - 11.19.2010, 08:42 PM
Not sure about the exact measurement, but those are HPI super heavy duty removeable cups with 8mm center holes. I would have to get out the calipers and measure the ball size when I have a chance to verify that for you.
_dV
11.19.2010, 06:02 PM
Those axles probably wouldn't have the cup size to suit the SHD Flux bones.
Why not
JERRY2KONE
JERRY2KONE's Avatar
Why not - 11.19.2010, 06:19 PM
Why not? I am using them on a 3906 EMaxx right now. I wanted a set of axles with some beef to them to avoid breakage in a very heavy duty setup, so I got a full set of these 8mm stubs and modified them to fit the Max knuckles runing them with dogbones. The thing is once you go beefy on one part of the drivetrain, then you have to go down the line and beef up every other part to that line in order to creat a bullitproof truck.
