_dV
11.19.2010, 06:02 PM
Those axles probably wouldn't have the cup size to suit the SHD Flux bones.
Why not
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Why not - 11.19.2010, 06:19 PM
Why not? I am using them on a 3906 EMaxx right now. I wanted a set of axles with some beef to them to avoid breakage in a very heavy duty setup, so I got a full set of these 8mm stubs and modified them to fit the Max knuckles runing them with dogbones. The thing is once you go beefy on one part of the drivetrain, then you have to go down the line and beef up every other part to that line in order to creat a bullitproof truck.
SUPERMAXX YOUR LIFE.
