Lst diff case question
Lst diff case question - 12.03.2010, 11:48 PM
Ok, so we still do not have a lst section... So I guess I will post here casue it is for my project x lst based 6x6.
Wondering if anyone knows of an alternative to the stock losi made aluminum diff cases. They appear to be squeeze cast and I would like something machined so I can cut to of them in half and tig weld them back together. TI am referring to the part that holds the assembled diff and pinion, not the diff case that holds the spider gears.
So any input would be appreciated.
Semi Pro
Semi Pro's Avatar
12.04.2010, 01:53 AM
i have some cnc'd cases that were made by hot racing,( or gpm, cant rember) i got them a very long time ago
12.04.2010, 08:25 PM
Interesting, they would likely work. Wonder if I can still find them? I should hit up flm or Mike, see if they can just machine me what I want. Probably be cheaper and easier in the end...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.04.2010, 09:00 PM
+1
I've ben looking on/off for 5yrs for anything better than Losi's "questionable at best" cast cases. Never seen any after market ones, would like to tho ?
simplechamp
simplechamp's Avatar
12.04.2010, 10:19 PM
Very surprising that with all the aftermarket support for the LST no one makes CNC machined diff cases. I've definitely never been a fan of cast aluminum.
Semi Pro
Semi Pro's Avatar
12.04.2010, 11:04 PM
they are pretty thin, if mike could make some im sure they would be much better
