Pdelcast
Pdelcast's Avatar
12.09.2010, 11:24 AM
when can we expect another motor or 2 to add to the SCT line of motors. How about a 1412 1D in the green flavor.... couple that with the MMP in a combo and call it a day.
i think the 1412 1D would be one hell of a 2s motor for the 4x4s that race on the largest of 8th scale tracks.
Unfortunately, our rotor design is a little different the the Neu designs -- they are optimized for Wye windings, and don't make good Delta motors.
How about a 1415 .5Y? That would be about 4800Kv.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
rootar
rootar's Avatar
12.09.2010, 11:29 AM
sounds good! that would one bad motor.
Pdelcast
Pdelcast's Avatar
12.09.2010, 11:32 AM
The only issue I see is that the max efficiency would be around 120A or so -- would need to be run with a Mamba Monster -- the Mamba Pro wouldn't be able to handle it.
Thanx!
Patrick
coreyfro
12.14.2010, 03:51 AM
Thanx!
Patrick
Would such a motor be ROAR legal for 1/10th 4x4 SCT? I've got a monster.
Pdelcast
Pdelcast's Avatar
12.14.2010, 11:12 AM
ROAR rules state that the motor must be 53.00mm in length or shorter.
So, it wouldn't be ROAR legal.
jhautz
jhautz's Avatar
12.19.2010, 01:15 AM
Patrick, Any idea when the 1410 and 1412 motors will be offered without the ESC combo? I'm all set on ESCs but would really like to get the motors by themselves.
to make it...
or break it...
Silent...But Deadly
Another question for Patrick...
ta_man
Another question for Patrick... - 12.19.2010, 12:44 PM
1410 motor has a 1/8" output shaft and I believe you mentioned that this was for ROAR requirements. I didn't take the motor apart to measure it but the bearing looks like it could accomodate a 5MM output shaft. If you offer rebuild kits for the 1410, would there be an option of a 5MM output shaft?
I have no concern about the 1/8" shaft in a car with a slipper, but in a CRT.5/SCRT10 or similar car with direct drive and exposed gears, I would be concerned that a stone in the gear could snap the 1/8" shaft (actually heard 2nd hand reports on RCTech of people snapping these shafts). Then you would have to replace the rotor anyway, so why not do it right away with a 5MM output shaft rotor?
kingdomracer
kingdomracer's Avatar
02.07.2011, 07:00 PM
Thanx!
Patrick
Any updates on this motor, will it come to production?
JESUS says "Fix it B4 it Breaks"
outlaw
Castle addicted
outlaw's Avatar
04.24.2011, 02:36 AM
Thanx!
Patrick
I would take one 100%
After seeing the 1410 1Y throwing around my RC8 to SC10 4x4 Conversion, I would love to have one, but please with 5mm shaft
kind regards
Mirko
Brushless motors have to be green ....
