The only issue I see is that the max efficiency would be around 120A or so -- would need to be run with a Mamba Monster -- the Mamba Pro wouldn't be able to handle it.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
Thanx!
Patrick
Would such a motor be ROAR legal for 1/10th 4x4 SCT? I've got a monster.
Patrick, Any idea when the 1410 and 1412 motors will be offered without the ESC combo? I'm all set on ESCs but would really like to get the motors by themselves.
to make it...
or break it...
Another question for Patrick... -
12.19.2010, 12:44 PM
1410 motor has a 1/8" output shaft and I believe you mentioned that this was for ROAR requirements. I didn't take the motor apart to measure it but the bearing looks like it could accomodate a 5MM output shaft. If you offer rebuild kits for the 1410, would there be an option of a 5MM output shaft?
I have no concern about the 1/8" shaft in a car with a slipper, but in a CRT.5/SCRT10 or similar car with direct drive and exposed gears, I would be concerned that a stone in the gear could snap the 1/8" shaft (actually heard 2nd hand reports on RCTech of people snapping these shafts). Then you would have to replace the rotor anyway, so why not do it right away with a 5MM output shaft rotor?
