doo540
12.26.2010, 03:15 PM
I'm planning on installing the new Castle Creations combo as a comparosin between the 12s and 8s setups.
Patrick from Castle said the 12s and 8s setups should have about the same output do to the 8s being able to handle more amps.
I will probably move the 12s setup into a Kalee 4x4 baja. That truck will look very much like the HPI baja but have 4 wheel drive, wider wheel track and a touch longer wheel base. I hope to have that project done before spring time.
