Semi Pro
Semi Pro's Avatar
12.29.2010, 08:53 PM
we are and here you go
https://sdp-si.com/eStore/
i would need to know alot more about thr pinion you need to find you the right one, but if it can be found it will be at sdp-si
tommyheadleycox
12.30.2010, 01:32 AM
Many, many thanks. I can furnish whatever information you need about the pinion in question. BTW- it was installed on a beautiful 1970's vintage large scale German train. I sent the original motor with gear intact to a dealer of coreless motors. He said he'd pull the old gear off and put it on a new Maxon corelss motor for me. But he tore the old gear up really badly with his gear puller. It had meshed very smoothly and when I got it back, it just locked up.
I may have made a big mistake by trying to gently remove the burrs with a dremel. It meshed a bit better. But it's still not right. And I'm just at a loss on what to do next. Should I buy several gears that are close to this one and hope for the best?
I can furnish pictures of the pinion, pictures of the spur gear it meshes with, measurements, whatever is needed. I appreciate very much your help, believe me.
Thanks,
Tom
Scan and fax exact size copy
tommyheadleycox
Scan and fax exact size copy - 12.30.2010, 04:46 PM
I just thought of something. Would it be of any help to scan and fax an EXACT 1:1 image of the gear? Accurate to .10 say.??
I also have taken a great many photos and measurements.
Thank you,
Tom
