thzero
01.04.2011, 03:31 PM
Same non-BP diffs that the XL has.
Originally Posted by josh9mille View Post
, but im not sure what diffs the X came with.
All the uprights, hubs, arms, etc. are the same between the X, XL and Flux. Only differences are that the XL and Flux both use the HD axles and dogbones; XL has wider axles than the Flux, about .5" wider. Because of the HD dogbones, the XL/Flux also use different cups than the X for the diffs.
As to the two Integy parts, I think the first one is an older part with the second one being a newer part. I've been running the second one with mine, using the X SS's adjustable upper a-arm.
