bdebde
That's All Folks!
bdebde's Avatar
01.30.2011, 02:15 PM
Update the firmware with a XP machine (32 bit) through the MM usb port. Then you should be able to use castlelink through the receiver plug on newer OS.
Thomas Porfert
Thomas Porfert's Avatar
01.30.2011, 03:20 PM
+1. You will need to update the firmware on your Mamba Max to version 1.26 or higher to work with the Castle Link adapter. You will need to hook it up to a 32 bit machine (most XP and some Vista's are 32 bit). Update the firmware via the side USB port. Once you have a newer version of firmware on the Mamba Max, it will work just fine with the Castle Link adapter on your 64 bit machine. Let us know how it works out, and sorry for making you jump through a bit of a hoop.
Thomas Porfert
Tech Support
