josh9mille
josh9mille's Avatar
02.11.2011, 12:27 PM
that thing hauls azz! So what kind of radio do you use for that? I would immagine it would be a stick radio for airplanes so you can control each track independently?
02.11.2011, 12:44 PM
It's actually a single motor with a differential with left and right brakes off one servo that steer a blizzard. Turn left and the left track locks. Turn right and the right track locks. Any radio would work.
Krawlin
Got brushless?
Krawlin's Avatar
02.11.2011, 12:51 PM
Actually Kyosho Blizzards use a differential between the tracks with a brake disc on each side. To steer, it uses a single servo that applies the brake on 1 side or the other. You can use a pistol type radio for this, but if one were so inclined, I guess you could use a stick radio for airplane, but really it would be doing the same thing, unless you set it up for dual motors, 1 driving each track.
EDIT: Whoops, Harold posted the same thing while I was typing this up.
Monster GT Conversion
