Help. Cant program 9918 -
07.13.2005, 11:32 PM
my red jumper broke again. So i resolderd it on and now im trying to program it. Well i follow the instructions and after i plug my batts in it beeps. Ok next step. I go to full throttle and then it doesnt beep. i held it for 30 seconds and it still doesnt beep. so then i went to full reverse, and it still didnt beep. Whats wrong?:P:
Site Owner
07.14.2005, 10:07 PM
How did you break the jumper? I would first check the obvious things, like the radio(tx and rx on same channel, etc.) . Also make sure the throttle channel isn't reversed, as this can sometime create a headache when trying to program the controller.
07.14.2005, 10:45 PM
The jumper broke off some how, i have no clue, must of been when i was bashing and fell on my rear body post(where the controller is) Ive checked the obvisious, i have 2 different rx, 2 different reciever packs, and 3 different channels. Ill test the reverse on the transmitter. Could i send this in to you for repair?
Site Owner
07.14.2005, 10:55 PM
If you don't get it figured out, you can send it back to me. I can likely find a spare programming jumper to solder on for you.
07.15.2005, 01:17 PM
Ok, ill keep that in mind for future reference. I got it to work finally. I used my brand new gp3700 and that seemed to do it.
07.17.2005, 11:09 AM
If you loose or break the jumper itself not the pegs. Go to a computer store. The jumper on back of a hard drive or cd player will work the same trick.
Peace!
Country
Help support the
Rc-Monster
Buy here
03.16.2006, 08:52 PM
I broke the pegs and lost the jumper.
I had to reprogram my ESC Again and now im having a problem with making the program stay. I use to solder a wire for a permenant jumper but its not working anymore. I program it, and then when i go to solder the wire on. I solder it turn everything off. Plug the batteries back in and it wants to program again. Any ideas?
Also if i send it in to you Mike, how long will it take for you to fix?
03.18.2006, 02:54 PM
Can anyone help? And have you gotten my email yet MIKE that i sent a week ago?
Site Owner
03.19.2006, 12:36 PM
If you got the board too hot while soldering your permanant jumper on and off, you may have damaged the board. If you sent an email a week a go, I have no doubt replied by now(almost never more than a day goes by for replies). Check your junk email folders.
If the board is damaged, I can't fix it. I would need to send it to BK.
03.19.2006, 01:18 PM
Ok. I'm going to purchase a new 9920. Could i send you a moneyorder for the price and send you my 9918. And if you could fix it can you, or could you send it to BK.:032:
Site Owner
03.19.2006, 01:27 PM
Yep. :)
03.19.2006, 01:34 PM
Thank you. Expect a money order and a 9918 this week.:028:
03.19.2006, 04:17 PM
I just went through the same problem your having, you have to have your remote set up right, before you program,what remote are you running?
No, you can't drive it!!!!! These's big boi tois!!!!!
03.19.2006, 04:20 PM
The stock HPI Savage one. But i dont see where your going with this. My 9918 wont keep its program. Thats my problem.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
