_dV
04.13.2011, 04:17 AM
Flux radio box has 30mm clearance from the mount point to the bit of plastic that would hit the base of the servo.
Looking at the diagram here http://www.savoxusa.com/ProductDetai...Show=TechSpecs it doesn't have the dimension from the base to the mount point like some of their other servos. Doing a rough proportional calc though off the diagram I get about 31mm. So likely you would have to modify the radio box.
Btw, that servo is brushed not coreless.
Homework...
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Homework... - 04.13.2011, 05:01 AM
Don't have a Savage myself, but do some measuring and compare. Here are the measurments from that link. What do you have room for? I am sure that you can make it work if you are willing to do a little fab work on your own. It looks pretty close from what I read.
40.7x19.6x42.4mm
SUPERMAXX YOUR LIFE.
