E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.14.2011, 10:47 PM
I would guess at least in the neighborhood of 15-20 minutes depends on driving style. I have a 17.5t (2200kv) with a mmpro in my sc10 geared 87/21 and I can get about 45 minutes on a 5600mah pack. Your motor is a lot hotter than that 17.5 in mine but a t3 is lighter than a sc10
Thomas Porfert
Thomas Porfert's Avatar
04.14.2011, 10:52 PM
It all really depends on your driving style. If you're doing a lot of high speed runs with heavy acceleration, your run times will be significantly lower than by running partial throttle, with a smooth throttle response. It could be less than 15 and well over 20 based on driving style. Lowering the timing advance on the ESC will help increase run-time slightly. Also turning on the torque limit feature will help as well. Every time the tires spin, that's basically wasted energy that wasn't used to move or speed up the truck. Using the torque limit setting will reduce the amount of power the motor pulls, which will in turn increase run time.
Your low voltage cut-off will also affect the usable run-time. A higher cut-off will engage sooner and reduce the amount of time you can run.
Thomas Porfert
Tech Support
Castle Creations.
speedy
04.15.2011, 05:41 AM
Hi !
I,m using the stock tires och a dirttrak so i have like no grip :)
i have problems with signal loss whith this combo ? i can run for 1 pack with next to no problems but when i put the second pack in the motor cutsout and that no fun hehe what can cause this ? i have a spectrum dx3 pro tx and ar300rx. And the packs are new and works perfekt in my e.maxx.
