06.17.2011, 08:16 PM
I don't think it's the Neu-Castle 4-pole design. Looks more like the older 2-pole CM36 Castle motors, before they updated to the rebuildable style. HPI had a system just like that OEM'd by Castle, their Motiv/Warp combo.
It says 4 pole in the description:
The 4-pole, 3900kV sensorless brushless motor delivers more torque with greater efficiency, to meet the demands of today's off-road vehicles.
Motor Specifications:
Dimensions:1.42 x 1.85 in (36 mm x 47 mm)
Weight (w/wires):6.54 oz (185.4 g)
kV (RPM/V):3900kV
Voltage Input:2S MAX
Shaft Diameter:0.125 in (3.175 mm)
Poles:4
Wires:13AWG Silicone, 6.89 in (175 mm)
Connectors:4 mm Male bullet connectors
The 1406 motors measure 36x49mm vs 36x47mm for this motor, so my guess is also that its a cheaper variant made to Duratrax specs, like the HPI Flux 2350kv motor which is a 1517 with cheaper magnets- not a bad little system for $100..
freddy
06.18.2011, 07:00 AM
2mm is nothing, and if look at them you notice the duratrax version have screw on the body for holding the front bell and in the original castle version the screws are countersink in the front, making it longer.
