Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
jamesban
08.23.2011, 08:49 AM
In the video you mentioned that you tightened it as much as possible, but the springs were not completely compressed, indicating that the perhaps the threads were not greased adequately. You should be able to completely flatten the springs without excessive effort – especially when out of the truck.
It was greased well and tightened easily, it is tightened so that the springs are almost perfectly flat. The ring is so tight there are only threads on the bottom half of the ring. There is absolutely no way to tighten it any mroe than it is now so if thats the only solution this will not work for me at all.
