Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
jamesban
09.04.2011, 02:32 PM
I got the third spring on last night and with the third spring and it tightened all the way down it works! The front end comes off the ground a little tiny bit on launch but no more flips or wheelies and my drive train should be safe now. So I guess with 3 springs it will work good on a huge truck like the muggy. Im happy with it now. Im running a 15t pinion, 4 cell A123 batteries and a 40 x 82 mm 2000kv 4 pole leopard motor. It moves pretty good! I will try to get some video posted when it stops raining.
cmac
cmac's Avatar
09.04.2011, 02:53 PM
What diff fluid are you using in the slipper?, and do you know how much you truck weigh's?
jamesban
09.04.2011, 03:49 PM
I was using 50k but last time I rebuilt it I had no fluid left so i just used diff grease. I have no idea how much my muggy weighs. Im guessing around 13lbs.
