Outrunners typically work better with higher timing. Try "normal" first. Also, depending on the vehicle/battery, start power can be raised also.
Because the CC controllers advance timing based on motor inductance, we usually recommend "low" timing for outrunners. So a little different than most sensorless controllers...
Thanx!
Patrick del Castillo
President, Principle Engineer
