maxxdude1234
maxxdude1234's Avatar
03.27.2006, 03:20 PM
A 1950 on 6s lipo should be able to do 50mph. Controller wise, a warrior 9920 would be about spot on, or micro 3695/36120 would give you the option of 8s lipo (if you decide you want insane power in the future). Also, the new mgm16024 might be worth a look.
nl12
nl12's Avatar
03.27.2006, 04:06 PM
My motor has not came in yet but I am building a Jammin CRT with a lehner 2240 10 turn on 8s lipo, I think it should be able to smoke any nitro, except maybe a 1/8 onroad. I am using a MGM 16024 controler as well. I think this setup is about as powerful as you can go with some degree of durability (I hope) within the next month I will get my truck going if my setup works well I will help you copy the same thing, if you would like. One downside my motor/controler/lipo setup is about $1000, but it will be a very sweet truck at least to me.
Gustav
Gustav's Avatar
03.27.2006, 05:52 PM
No, it will have zero degrees of durability.If/when the hybrid bulks come out it may have a prayer,although it will need a center diff conversion,coolhand has been tearing the little keyways off the strobe i believe.
