Thread Tools Rating: Thread Rating: 17 votes, 4.76 average. Display Modes
coolhandcountry
coolhandcountry's Avatar
12.15.2011, 04:29 PM
Does the wide arm kit make it bump steer or anything?
Seems it would throw things out a little.
Peace!
Country
Help support the
Rc-Monster
Buy here
pietrvds
12.16.2011, 09:37 AM
ahaaa i was reading it wrong lol i thought your truck was 30mm widened on each side with those braces....
anyway you don't experience any troubles with the different angle/movement you now have and the dogbone going from diff output axle to drive axle???? strrrange i thought it was going to rub against the lower a-arm....
My arms are going back to the drawing table, i'm not happy with them lolz so it will take some more time but they will be better :)
the custom dogbones are finally arriving this monday or tuesday in the mail so i'm pretty psyched about that!!!! after a couple of months of waiting and looking for manufacturers :)))
will update soon :)
Knez
Knez's Avatar
12.16.2011, 06:22 PM
coolhandcountry - can you explain a bit your question... sorry just my english sometimes gives me trubels.
pietrvds - Truck is total widened for 30mm or there about... i got bad mesuring tool almost older than me
No trubles or any other problems with dogbones except the 2 short pins on FLM dogbones.
I really cant wait for your arms.. i am waching your thread closely :)
And dont forget to post the pic of the dogbones you receive!
oh wich manufaturer made yours ?
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
coolhandcountry
12.16.2011, 08:35 PM
It looks as if your arms was moved out from factory positions.
Doesn't look like your steering linkage moved anything.
That in turn may make it drive differently over bumps cause of geometry defference.
Maybe the wheelbase makes it less noticable.
Peace!
Country
Help support the
Rc-Monster
Buy here
Knez
Knez's Avatar
12.16.2011, 08:51 PM
Arms where moved out form factory position as it is wide brace kit.
Before car was 44cm wide now is 47cm wide.
Steering linkage i replaced the shaft (Stock M4x70mm for M4x80mm)
From this stock HPI 93535 Turnbuckle M4x70mm
http://www.ebay.com/itm/HPI-93535-Tu...item336d63c80f
To this HPI Nitro Hellfire SS Turnbuckle M4x80mm Hellfire (2) HPI86535
http://www.ebay.com/itm/HPI-Nitro-He...item2316ed319b
Well i wanted wider car because of the 5b lenght.
How it will handle i do not know, but I got a feeling it will be good.
Test will show more. Wish it would stop raining for 1 freaking day.
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
12.27.2011, 10:36 AM
Sold my XeRun150A yesterday and today i received this from Castle :)
A very nice A!
Flux 5B CC 1520
1/16 Rally
My Youtube
pietrvds
12.27.2011, 01:45 PM
WOOOOOOT! :)
and will you also purchase a 2028 for it or a leopard....?
Knez
Knez's Avatar
12.27.2011, 02:04 PM
You mean new motor for CD?
I got 1520 on it and will use tranny for now :)
What i was thinking is going to 8S with 18/44T.
Flux 5B CC 1520
1/16 Rally
My Youtube
pietrvds
12.27.2011, 02:55 PM
What's the idea behind that? couldn't you just adjust gearing instead of using more cells? ;)
have you got any more news about those shocks? are they holding up ok?
Knez
Knez's Avatar
12.27.2011, 03:13 PM
Idea is a bit more speed and more driving time.
Shocks are holding so good, i wont change these for no others.
I did have only 3 hard tests, befor my antena started to glitch and so on.
But i am loving these.
Flux 5B CC 1520
1/16 Rally
My Youtube
pietrvds
12.27.2011, 03:26 PM
very good to hear that! can't wait to test them also....
did you change the oil or did you leave it factory filled and just changed the white springs?
I like soft dampening alot so thought of drilling the pistons but if you're allready satisfied with the factory oil and the yellow springs ... ;)
Knez
Knez's Avatar
12.27.2011, 03:34 PM
I did not yet tested yellow springs, but i do have factory oil in shocks.
With white springs is driving ok but more for jumps and so.
Yellow are no way for jumps but driving should be a lot better as car sits very low, similar to S8 Bxe. i do have 3 preloaders or shims for springs on.
On front even 4 i think.
What i need to do is solder the 6mm connectors on MXL2 and go ut to test the yellow springs...
Hope i wont be too lazy..i mean the weather here and cold...i perfere a neat place :)
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
01.20.2012, 09:25 PM
Hi all, here some buddy codes if anybody needs anything from here even cheaper than it already is.
Budy Codes:
________________
Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g
http://www.hobbyking.com/buddy.asp?c...2-FD211DAA39DB
________________
Turnigy S8166M Servo 154g / 33kg / .21sec
http://www.hobbyking.com/buddy.asp?c...8-04267E872C13
________________
Turnigy AA LSD 2200mah Low Self Discharge (ready to use)
http://www.hobbyking.com/buddy.asp?c...9-762DEF0B55DA
________________
Turnigy nano-tech 4500mah 6S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...4-D3308CA7D02B
________________
HXT 6mm Sprung Gold Connectors (10pair/20pc)
http://www.hobbyking.com/buddy.asp?c...9-05296F1BE68F
________________
Turnigy Heat Shrink Tube 10mm BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...E-9574EBB4E7EC
________________
Turnigy Heat Shrink Tube 10mm RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...3-CF01780BA483
________________
Insta-Flex Flexible Thin CA 1. oz
http://www.hobbyking.com/buddy.asp?c...C-F50183706A4D
________________
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...9-539F29EC3043
________________
Parts Container 165x90x40mm
http://www.hobbyking.com/buddy.asp?c...D-B4DAEF9BBBDE
________________
Wire Mesh Guard Blue 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...0-1C411E71BE8F
________________
Wire Mesh Guard Red 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...7-766949578C20
________________
6inch Spring Clamp Tool
http://www.hobbyking.com/buddy.asp?c...4-ACE1AF5850BD
________________
5pc Rigid Cleaning brush set.
http://www.hobbyking.com/buddy.asp?c...7-2826ECFBED2F
________________
Turnigy Long Shaft 4pc Hex driver set
http://www.hobbyking.com/buddy.asp?c...1-8D5B98646774
________________
Turnigy 2mm long shaft Hex Screwdriver
http://www.hobbyking.com/buddy.asp?c...4-99E07C016B35
________________
Front Tire Set - A2003T (2pcs)
http://www.hobbyking.com/buddy.asp?c...C-B8F13AFF94E9
________________
http://www.hobbyking.com/buddy.asp?c...7-8B7347F3D440
________________
TURNIGY Plush 40amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...B-64B6A6274BB7
________________
TURNIGY BESC Programming Card
http://www.hobbyking.com/buddy.asp?c...3-D1A50C8A5D36
________________
Hobby King 401B AVCS Digital Head Lock Gyro
http://www.hobbyking.com/buddy.asp?c...0-8883058A0959
________________
GT450PRO Drive Gear Set 11T/13T 3.15mm
http://www.hobbyking.com/buddy.asp?c...C-245EF14E8372
________________
Turnigy Battery Strap 330mm
http://www.hobbyking.com/buddy.asp?c...6-A3B59DF1E6C9
________________
Roof Guard / Roll Cage Baja 260 and 260s
http://www.hobbyking.com/buddy.asp?c...8-6495DCC75051
________________
Regards,
Knez
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
02.02.2012, 11:11 AM
MXL2 is back on Savage 5b flux baja.
What i need to do is secure the front lights and set the angle for them.
Also need to buy some lipos as i sold them all and got a new baja 5b body to spray / paint.
Rear wing is now secured and it is not moving. What i did i used small plastic peace and just stick it to the wing,
turned upside down 1 side of alza upper racing shock kit wich is now working as a support for wing.
Now next to do is Green locktite on the motor pinion, if that goes loose i will try red locktite.
Flux 5B CC 1520
1/16 Rally
My Youtube
Knez
Knez's Avatar
03.04.2012, 05:15 PM
Here another video...
Steering much better now, i grinded a little so now it turns more.
I tested White springs in front with no preloaders and yellow springs "soft" at the rear with 3 preloaders on each shock.
Green locktite on motor pinion !!!
It holds for now, 3 runs all good.
http://www.youtube.com/watch?v=a1YHEjRw4cQ
[YOUTUBE]http://www.youtube.com/watch?v=a1YHEjRw4cQ[/YOUTUBE]
Flux 5B CC 1520
1/16 Rally
My Youtube
