Overdriven
Destroyer of Tires
Overdriven's Avatar
01.08.2012, 11:22 PM
Definitely go micro on the servo, no need for anything bigger plus they have only 2 mounting holes instead of 4 making things a little easier.
How much room do you need to mount the motor up front? Can you grind down the summit mount to move the motor back a bit? I was going to do that on my e-Revo to squeeze a 1520 in it without hitting the shock mount. Just make sure you can get the pinion on the motor and mesh right before you shave the mount down. Also if you mount the spur backwards it'll give you more room to shave the mount down more. I forget how much room you can get if you do all this, but it's something to look into. Would look neater with the motor up front than the esc, plus I like having as much weight up front in my Maxx trucks, seems to help on power steering and suits my driving style better.
