pietrvds
01.15.2012, 09:07 AM
ok now i had some time to work on my diffs...always a pleasure humhum...
I changed all the cups to vorza cups, used the HD spider gears from hot bodies and changed all the bearings with boca bearings, the yellow ones who should be pretty dirt proof.
encountered a problem with the bulkheads... it seems you have to use a thinner inner bearing otherwise the pinion doenst fit...
anywayz don't know if the problem is with the bulkheads but i ordered thinner bearings from boca.
pics:
painted the carriers in metallic black and changed all the bearings with yellow boca ones also
mothman
01.15.2012, 11:53 AM
pics:
I believe the one you have is the super hybrid bulk:
http://fastlanemachine.net/proddetai...LM40020&cat=22
This bulk is designed to be used with buggy diffs. Since the ring gear of the buggy diff is smaller, they moved the pinion section towards the ring gear. That is why you cant use the 16x8x5 bearings. So what bearing size did you use?
