ok now i had some time to work on my diffs...always a pleasure humhum...
I changed all the cups to vorza cups, used the HD spider gears from hot bodies and changed all the bearings with boca bearings, the yellow ones who should be pretty dirt proof.
encountered a problem with the bulkheads... it seems you have to use a thinner inner bearing otherwise the pinion doenst fit...
anywayz don't know if the problem is with the bulkheads but i ordered thinner bearings from boca.
pics:
painted the carriers in metallic black and changed all the bearings with yellow boca ones also
