pinkpanda3310
pinkpanda3310's Avatar
01.29.2012, 07:45 AM
I ran this car for the first time today. Went reasonably well, not the best. Handling was good but I busted the steering twice. Initially I was concerned the 2 x 10th scale servo savers were too soft, in the dirt they worked OK. I busted a screw holding the ball end to the spindle then I bent a lower arm on one of the savers.
Here's a shot kind of showing the steering setup (note theres no screws at time of pic)
The only bit of video I took of it
http://youtu.be/fUciY9B7eG0
Along with fixing the steering I want to make a stronger wing mount. I didn't break it, I just don't have confidence in it.
Carnage!
pinkpanda3310
Carnage! - 08.26.2012, 08:36 AM
Carnage today. I've had a reasonably good weekend, nothing special just enjoyed it. A neighbour came over for a little chit chat and I got out the car for him to buzz around. He wanted to know if the tires/wheels made much difference so I changed them from integy sq's (worn down to bald) to the stock atx's. He buzzed it a bit more then handed the control over. I don't like the handling of the atx's on the street but I guess that's no excuse for ripping my car in half. I went onto a verge and clipped a tree with the back right wheel at high speed. The main chassis continued past the tree another 10 metre's or so, the whole rear assembly flicked 7 metre's across the road perpendicular to the tree. I thought I had totally screwed the carbon chassis but when I retreived the two peices I was happy to find I had only sheared/snapped/stripped the 5 screws that secure the rear assembly.
I'm thinking I'll just drill and tap the bulks for a larger screw and I'll be in business again. Just try not to do it again, the cf might not hold for larger screws, it went with quite a thump
