Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
02.17.2012, 07:57 AM
Correct me if I am wrong, but Robin liked the Ofna shock design so much that he contacted them and asked if he could make bodies, caps, and shafts to fit his needs, and no other stock Ofna shock is the same size as the Supershocks.
Ofna Front shocks are way too short,
Ofna Rear shocks are way too long,
UE Supershocks are just right!
Anyway, as I was told, the Supershocks are part Ofna EXCEPT for the BODIES, CAPS & Ti Shafts...they are NOT stock Ofna Parts. So, if you want REAL Supershocks and they are not in stock at the UE Store (if they are, just buy them there), you need to buy the BODIES, CAPS & Ti Shafts from the UE Store and then buy Rear Ofna shocks (I like Ravager Rear Shocks) and swap out the Bodies, Caps, Shafts & cut the shaft booties a little shorter to fit properly.
Edit: He did the same with the UE 4-Shoe Clutch...he liked the design but wanted to make it better so he redesigned it, asked Ofna if they wanted first run at it, then starteed selling them as UE Products since Ofna didn't want it and gave him permission, just like with the shocks.
-Chad
PM ME IF YOU HAVE THE BELOW:
