sikeston34m
sikeston34m's Avatar
03.28.2012, 10:15 PM
On a brighter note, I did take it for a run.
I installed the Medusa 36-60-1500kv and geared it 18/52 using Mod 1 gears.
Then on 8S, this spins it up to around 45000rpm's.
This little motor comes to life on 8S. It has alot of power. It got a little warm during the times when I was cracking the throttle wide open. It just screams though.
Maybe I love a tight slipper a little too much because it twisted the yoke off the front differential.
Why the front? I don't know. I found the drive cup with the yoke still installed inside, but I lost the front dog bone!
I'll find it tomorrow, I hope.
The Mamba XL is a SWEET Esc. It did not break a sweat.
I also logged the run, which is really cool.
Top Watts was 2133 watts!
Max amps pulled was 76 amps.
Max ESC temp peaked at 120 degrees, which isn't bad at all.
