Also - take off servo horn and make sure you have enough travel - both ways - and make sure your servo is not limiting your steering - If the servo is off center - that would also keep the steering inadequate....... Report back and let us know if you found the problem. And Welcome to the forums.....
well, i figured out the problem, i did have to re-center the servo, but the problem for the ofset height what that one of the shocks had a different type of lower plastic mount that bolts to the a-arm....... fixed it, now their all even, used the little pieces off my rusty shocks......, thanks.
