nastety92
06.15.2012, 08:34 PM
Just got my D8T with 1520 all programmed and the correct gear on.
Damn this thing is fast now. It was quick before, now it's fast. The mid range is much more than the Tekin motor and I'm still running it very easy.
5s with 17/50 gearing.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 17
Total Voltage: 18.50
Motor KV: 1600
Tire Diameter (inches): 5.84
Tire Ballooning (inches): .10
Motor Current Draw: 140
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 12.64706 : 1
Tire Circumference (inches): 18.98 inches (481.97 mm)
Rollout: 1.50:1
Total Motor Speed: 29600 RPM
Vehicle Speed: 42.06 mph (67.56 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
Motor Torque: 0.62 ft-lbs
Final Torque: 7.79 ft-lbs
Final Power: 2590 watts (3.5 HP)
I think my next purchase is some 3s lipo's so I can run this motor on 6s. It should be interesting.
Video coming soon.
Nick
Tamiya TRF801Xt-e
06.16.2012, 04:03 PM
Other Ratio: 1
Motor KV: 1600
Rollout: 1.50:1
Video coming soon.
Nick
That stat is key to cool temps and a lot of fun!! Of course the 3.5HP and almost 8ft-lbs of torque doesn't hurt either
nastety92
06.17.2012, 09:07 AM
So what your saying is that lower RPM's keep the motor cool?
I've run that speed calculate with 6s and RPM's are 35,000. Is that to high? On 4s the RPM's are down in the 24-25,000 range and the truck feels slow.
Thanks again for the help,
Nick
Tamiya TRF801Xt-e
