Popoxx
Sapere aude
Popoxx's Avatar
09.10.2012, 02:05 PM
I'm always addicted don't worry My maxx is almost fixed, I just need an UE shock standoff.
What's new ? :
- Ejector pins :
I use Berger Tools pins now, this supplier can cut them to the length I need (3.06") and they are sturdier than the Plastixs pins I used before (I can't cut them with a bolt cutter !).
The ejector pins can't move thanks to the bumper mounts and skidplate. "Plug and play" :)
Front
I can't replace the front lower hinge pins because of the shape of my skidplate. I keep using Lunsford hinge pins here.
Rear
- Chassis braces : I replaced the bent chassis brace with a new one and 1offrc anodized it (fast and great job).
- Body posts : new ones from RC Raven :
With HPI body clips (really hard to bend !). RC Raven nylon seems similar to RPM nylon so I hope these posts will hold out. UE posts included with the shock towers aren't a direct fit (they have to be cut/drilled, boring... ).
