10.05.2012, 09:13 AM
I just ran #'s through the calc...w/your setup using a 13t pinion you are looking at 32mph, w/a 18t pinion you are looking at 44mph. The only issue is the motor RPM which is spinning over 43K which is too much IMO if you want the motor to last.
On a 6s setup a 1300-1500kv motor is best for longevity and good performance. If pure speed runs are what you are after, well then that's a whole different setup.
Just my 2cents worth
