WheelMan
Do Epic Sh!t
WheelMan's Avatar
01.18.2013, 12:31 AM
I used the following to shim both my FLM Hybrid Bulks
And I got them here.
One pack comes with 3 different thicknesses, and they're stainless steel. Worked like a charm I thought.
The shim you measured that comes with the bulk goes in one side before the bearing goes in, it helps to shift the diff to one side or the other for pinion mesh. But shims are still needed. Do not put the shim that comes with the bulk inside, it has to go in the bearing seat, towards the outside. Kind of hard to explain. I can get you a picture if you need.
-Travis
Adults are just kids, with money.
Common sense, is not so common.
Xcaliber
01.18.2013, 01:06 AM
Yeh a picture would be awesome this is my first flm bulk and I want to do it right. It came with 0 instructions so i was clueless lol.
WheelMan
Do Epic Sh!t
WheelMan's Avatar
01.18.2013, 01:06 PM
ok, so the large diameter shim that came with your bulks, will go in where I've pointed with the red arrow, in front of the bearing...towards the outside of the bulk. If you look closely, you can see part of it showing from the outside (the gear mesh will determine which side you need it on though...so don't just put it on the same side as mine, yours may require that it be on the other side)
The side you install it on will push the bearing in just a tad, as you can see below, but don't worry, this will not hurt anything. 90% of bearing is still seated.
And the shims I showed you up above will slide onto either side of the diff, where I've pointed below. This is where you will fine tune the diffs final placement, side to side, so the gear mesh feels good, and so there is no side to side slop
Sure hope this helps!
-Travis
