WheelMan
Do Epic Sh!t
WheelMan's Avatar
06.21.2013, 12:10 PM
The G4 has been monoblock'd.
It had to be done. Just didn't look right without it. Plus, the rear center bone that I got with the chassis is made for use with a mono, soo.... I guess it had to be done lol
Took some careful dremel work (didn't turn out perfect, but not bad for being done by hand)
-Travis
Adults are just kids, with money.
Common sense, is not so common.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
06.23.2013, 11:53 PM
Awesome build!
WheelMan
Do Epic Sh!t
WheelMan's Avatar
06.24.2013, 10:25 AM
Thank you sir
Got this purdy new shell for it in the mail over the weekend
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
06.27.2013, 08:44 AM
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
06.28.2013, 10:33 AM
5/16" Aluminum round stock for custom body posts
And some aluminum set screw collars
They ended up a little long, so I need to cut them down still
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
07.02.2013, 02:43 PM
Thanks to Justinbolin, I have a purdy new servo saver for this truck
And because I like to make what I already have work (and because I'm too impatient to wait for parts), I modified a set of TRX 7075 Tie Rods for the front. I removed the double threaded ends, tapped the tie rod tubes out to 8-32 to accept some cut down ss screws so I could attach the plastic rod ends. By eliminating the original double threaded ends, I was able to shorten the tie rods just enough for them to be the perfect length.
Now I just need to de-anodize them so they match the rears.
-Travis
