12.02.2013, 10:43 PM
4000w rms??? That must be some battery/charging system you have! Even assuming 90% efficient class-D amps, that's around 370A @ 12v - assuming the battery will hold at 12v when that level of current is being pulled. I hope those systems come with a complimentary set of earplugs. :)
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.03.2013, 12:52 AM
Double layered 1 1/2" sub box, insulated and wrapped in vinyl, Class D Amps, 220A Alternator, 30Farad CAPS(2), extra - Kinetik HC3800 Battery, 1/0 Gauge wires all around, Crossfire C51700D Amp (2), RE Audio XXX 12" (2).
There are a few value amps and subs available on their special deals which come once every week/month or so.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
