whitrzac
Can't catch this...
whitrzac's Avatar
01.31.2014, 09:22 PM
Originally Posted by Thomas Porfert View Post
An older version of the Castle Link that is unencrypted wouldn't help. Old versions (over ~1 year ago) of Castle Link won't have the ET-3S because the ESC was released afterwards. Old versions of Castle Link don't support newer ESCs. So even if you had the unencrypted versions of the Link they won't recognize the ET-3S. I can't think of anyway to remove the over-voltage protection without direct access to the code. And of course if I did I wouldn't post it to a public forum...cause ya know, I like my job. :)
Thomas Porfert
Tech Support
I won't tell if you don't. While you're at it, the decryption key would be nice.
This forum has a fancy feature that allows you to send a 'private message' that no-one else can read
I was hoping over voltage t just turned off the BEC, but it completely shuts down the esc.
Don't make me start transplanting ICs. I have a few fried normal MMPs that would make good doners..
Lizard
Lizard's Avatar
01.30.2014, 01:25 PM
I think it should be possible to crack it by running the program with a debugger/tracer in the background that will trace API calls. Somehow the database must be decrypted during runtime and thus the key will probably show up when the database is decrypted/loaded.
