OK, with FLM Hybrid bulks and 1/8 diff, using the Slipperential diff in the center, dogbone lengths required are around 82-85mm pin to pin in the front and 107-110mm pin to pin out back(82mm and 110mm or 85mm and 107mm). Diffs do have slight variances in size, as do drive cups, but the skid is slotted to accommodate this.
