Mr E-Maxx
Mr E-Maxx's Avatar
08.26.2015, 10:30 AM
Hi,
yes parallel is rigth. I think 4-5mm^2 (12-10AWG) should be enough but bigger is better.
Pdelcast
Pdelcast's Avatar
08.26.2015, 10:47 AM
Parallel is correct.
However, you want to keep the length of the wires to a MINIMUM, as long wires negate the effect of the extra capacitance.
Also, use heavy wires -- maximum currents sourced and sunk by the capacitors can be very high (>100A for short bursts) -- so they need heavy wire to reduce inductance.
Thanks!
Patrick
Patrick del Castillo
President, Principle Engineer
ruudxd
08.26.2015, 02:29 PM
Ok, thanks guys!
So the best is to solder wires as close to the ESC as possible to have the shortest wire length?
Or would it be better to build a cap bank that has an extra cap or two to reduce the extra length of wire?
Pdelcast
Pdelcast's Avatar
08.26.2015, 03:44 PM
Originally Posted by ruudxd View Post
Ok, thanks guys!
Either is acceptable. Whatever is easier in your installation.
ruudxd
08.28.2015, 12:40 PM
Ok, I will take a look at the cost of some good caps.
Thanks a lot for the help!
ruudxd
09.02.2015, 03:08 PM
Sorry to bother you again, but I did some other research on a Dutch forum, and found out that boating guys use cap packs to, like this one:
http://www.tfl-hobby.de/product_info...3-000--f-.html
But does anyone know why they can use thinner wires?
The wires on the pictures don't look like 10 gauge wire, but the ESC's I have seen used are 220 amp ETTI's, Castle's etc?
Not that I do not trust you guys, I deffinetly trust you guys, and appreactiate the tips and advice, but I was just qourius?
