Pdelcast
Pdelcast's Avatar
12.08.2017, 02:44 PM
Originally Posted by maxxximatoze View Post
Thx for the answer. It was sensorless. I have tested both mode and no real differences between the two. The advance is set to low (0 to 5 if I remember well) with castle link.
Not surprising you didn't see a difference -- even in sensored mode, timing above a certain threshold is dominated by the sensorless routine. (which makes sense...)
You are probably close to the maximum 5 degree advance at 24V, so your rise in current is normal.
Thanks!
Patrick
Patrick del Castillo
President, Principle Engineer
maxxximatoze
12.08.2017, 07:45 PM
Thanks!
Patrick
OK good to know. I will try with 0 timing to see what append and report here...
maxxximatoze
12.08.2017, 07:48 PM
On the motor box I can read "revision date: 03/17" and "PKG: 6140-03-0401". Maybe it's not a genuine castle 1515 ? If it's the case it would be a very nice (and expensive ;) ) counterfact !
maxxximatoze
12.08.2017, 07:52 PM
Could very good bearings (like boca ceramic abec 7 for exemple) reduce I0 losses and if yes in which proportions ?
maxxximatoze
12.09.2017, 06:38 PM
For I0, I have tested at 0 timing. Same results at all voltage.
For phase Rm, I have double checked every of my measures of the new 1515 and all the results are good.
AB=5.6 mohms at solder tab 7 mohms at bullet
BC=5.6 mohms at solder tab 7 mohms at bullet
AC=4.4 mohms at solder tab 5.8 mohms at bullet
Just to compare here is the results for my old hpi alphastar 2350kv made by castle with shortened wires (old design without solder tabs)
AB=6.2 mohms at bullet
BC=6.2 mohms at bullet
AC=6.2 mohms at bullet
Perfectly equal phase to phase. I have to say that I am a bit desapointed by the result of the 1515 sensored. I will have to check how the coper wires are connected to the tabs, maybe a defect. How can I check if it's a genuine castle ? Amain is a reputable store, isn't it ?
Pdelcast
Pdelcast's Avatar
12.11.2017, 06:22 PM
Disappointed by what?
Those are excellent numbers. At 100A, the whole motor is only dissipating 50W.
The difference is simply that there are tabs -- and A & C phase have slightly higher resistance because they go farther around the rear of the motor, while the B phase terminates right at the terminal.
Perfectly normal. The motor phases are balanced, there's just some additional resistance on A&C for the tabs.
Thanks!
Patrick
maxxximatoze
12.11.2017, 07:00 PM
Thanks!
Patrick
OK, it's certainly perfectly fine. Do you if high grade ceramic bearing can reduce I0 in a measurable manner, or it's useless ? (and make it run noise free, the orignal bearings tend to make some noise at different rpm)
Ps: what is the toshiba mosfet ref used in the mamba monster X, if it's not top secret, TPHR6503PL ? just to know... And I promise, I stop bother you with all my questions ;)
Pdelcast
Pdelcast's Avatar
12.12.2017, 03:57 PM
Ceramic bearings can make it both quieter and reduce IO -- but be careful, they damage easy. And the front bearing is especially easy to damage.
I can't comment on what MOSFETs we use. But you can probably read the numbers off the top of the chips if you are interested. :)
