Programming MGM controller
James
Programming MGM controller - 06.12.2006, 08:45 AM
I searched for other threads about this, but i didnt find a answer. I turned on my esc, and radio, and after 10 seconds it beeps. I tried doing the foward then rezerse thing, but it doesnt work. Every time i turn it on it beeps after 10 seconds.
MetalMan
MetalMan's Avatar
06.12.2006, 08:50 AM
Just a single beep after 10 sec.? You may have to mess around with reversing the throttle channel (on the transmitter) and playing around with endpoints (if you can do that).
James
06.12.2006, 08:51 AM
No it keeps beepoing after 10 seconds, and i dont understand the directions.
James
06.12.2006, 08:52 AM
I have never programmed a esc before, and this is my first brushless
MetalMan
MetalMan's Avatar
06.12.2006, 08:53 AM
Is there a particular pattern to the beeping? The instructions have a list of the error codes that relates to the pattern of the beeps.
Tazz
Custom
06.12.2006, 09:19 AM
What MGM controller are you using and are you using a ubec?
James
06.12.2006, 09:35 AM
its just a beep beep beep beep, and a red flashing its the mgm 80 the smallest one
coolhandcountry
coolhandcountry's Avatar
06.12.2006, 01:08 PM
I had a problem like that. I had the epa on tx to much.
Peace!
Country
Help support the
Rc-Monster
Buy here
James
06.12.2006, 06:50 PM
I tried it again, and no mater what i do, it beeps continuesly after 10 seconds
James
06.13.2006, 01:10 PM
has anybody had this problem before
Cartwheels
06.13.2006, 03:54 PM
I had a problem like that once with my MGM. I ended up having to use a different radio system.
James
06.13.2006, 03:59 PM
I have two other radio systems, but do you have to program the controller to use it?
MetalMan
MetalMan's Avatar
06.13.2006, 04:19 PM
Yes, the controller needs to be programmed. Otherwise, it doesn't know what neutral, full forward throttle, and full reverse throttle are.
coolhandcountry
06.13.2006, 06:10 PM
If 100% epa don't work try 80%. It may have to much movement. Make sure you are pushing the right dirction. I was doing that at first as well. If the full forward doesn't work try full reverse and see what happens when turning on the esc.
Peace!
Country
Help support the
Rc-Monster
Buy here
James
06.13.2006, 06:47 PM
Im ready to retern this stupid controler.:019: Im 13 and so $700 is like someone with a job spending like $10,000, and it feels like I wasted all my money on this thing because it doesnt work. I had it for over a month, and its still not working. Can i call the owner mike? Is his phone number anywhere?
