danverz
08.09.2006, 04:23 AM
Ciao,
go for the hi-amp version.
The "normal" one has 3 female 3.5 gold plated connectors made by 2 parts joined together
by pression. It's easy to break off them. I broke off one of them early in my bashing.
Another thing I do not like about the "normal" version is that the current drawing can go
up to 100 Ampere and that 3.5 bullet connectors risk to be a resistent point for the current
flow. If just one phase has an higher resistence, makes the controller heating up.
So I say go for the hi-amp version, do not use any connectors, keep the cables as short as
possible, and finally use a silver solder pond.
Just my 2 cents,
Ciao,
Daniele
squeeforever
squeeforever's Avatar
08.09.2006, 09:44 PM
Originally Posted by danverz
Ciao,
Just my 2 cents,
Ciao,
Daniele
I wouldn't worry about the connectors. If you are, just get the 5.5mm connectors. There rated for something like 200 amps I believe.
danverz
08.10.2006, 03:18 AM
The problem could be about the connectors but it could also be about the
welding. Soldering the cables into the connectors and soldering cable to cable
is very different.
I also have to say you have to do 2 weldings for each cable with the
connectors, instead of just one if do not use it.
Do you often change the motor ? This is the only right reason to use
connectors. Any others are not techincal reasons :)
Ciao,
Daniele
