BADBOY2
09.13.2006, 09:37 PM
thanks guys..when it sizzled there was a black liquid that came out on the side of the esc casing..so i think thats not just the BEC..so the quark125 can only use 8cells?is that combined or per pack?im gonna be using a total of 12cells of ib3800s is that good?
anyway are feigao nemesis and wanderer both the same?just different labels?
jhautz
jhautz's Avatar
09.13.2006, 10:30 PM
You can use up to 16 cells on the Quark125, but f you are using more than 8 cells you need to disable the internal BEC by unpluging the red center wire on the plug that goes to the Rx. Theinternal BEC is only designed to take 8 cells max. The rest of the esc can handle 16 cells.
You should use an external BEC anyway. It takes the load off of the ESC and helps keep it cool. http://www.rc-monster.com/proddetail.php?prod=6vubec
Yes, all of theose motors are the same. I like the Feigao with the heat sink fins built right into the can. http://www.rc-monster.com/proddetail...540C_XL&cat=20
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
09.14.2006, 02:28 AM
Black Liquid??? That sounds kind wierd...
Like melted plastic? Did it staty liquid?
to make it...
or break it...
Silent...But Deadly
