danverz
09.19.2006, 08:06 AM
Hi,
if you charge at .1A probably you reach the imposted time limit on the triton,
so the max charge you'll be able to put in with theese settings is 1A.
Just try to remove the time limit, and try to set an higher delta peak.
Ciao,
Daniele
