Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
23 mm adaptors for 6mm axles
jmarko
23 mm adaptors for 6mm axles - 09.25.2006, 01:04 PM
Hello I have an emaxx with the UE 6 mm axles and the 14 mm nuts. Where can I find some 23mm adaptors to use with these axles. all the adaptors I see are for the standerd emaxx axles with the little pin through it not the hex shape. Thanks
Serum
Serum's Avatar
09.25.2006, 01:08 PM
Dace are the apaptors you need. Available in blue and black. They use a 14mm hex.
neweuser
neweuser's Avatar
09.26.2006, 02:28 PM
the dace are real nice. And they work great! I run them with my UE 6mm
Sneeck
RC-Monster Custom
Sneeck's Avatar
09.26.2006, 02:52 PM
Dace only work's with the ue cvd's. Way better than the pin-type cvd adaptor's, since the pin will wear into the alum.
  Send a message via MSN to Sneeck
neweuser
neweuser's Avatar
09.26.2006, 02:58 PM
Actually Sneeck, any 14mm hex will fit into the dace....even the stockers. But if you put the stockers on too tight, the pin will wear thru yes.
Sneeck
RC-Monster Custom
Sneeck's Avatar
09.26.2006, 02:59 PM
Doh, yes your right. I keep thinking the dace will go directly on the cvd.
Serum
Serum's Avatar
09.26.2006, 05:34 PM
LOL, that's what i thought when they launced them too.. A 5mm hex instead of a 14... :p
