Originally Posted by Serum
That could be a problem. Are you planning on running the LST with the 2speed? that mount fd uses is kind of weak. you are better off making your own. you can also get a FOC for the LST, which makes it light. As far as i could see it, it looks like it locks it in gear as well.
Actually it eliminates all the gears except for thr high range (reverse and lowrange) that the racer doesn't need. I just got an LST with all LST2 parts and honestly the low range is as useful as first in a emaxx
