Serum
Serum's Avatar
05.13.2005, 04:05 AM
I think your quite a legend yourself with your BL revo, which is by far the best conversion i have seen yet. You simple forgot about the exisistence of the allmighty google.
But, correct me if i'm wrong, are you going to use two servos for steering? Is it a revo? (i know/read your working on a new BL revo right?) Ever considered the new ultrahigh torque TG series of hitec? They are a blast, at 24 kg/cm / .15 seconds They are a bit pricey, (115 dollars) HS-5955TG is the name of this little diamond.. but if your planning on using two other servo's i would consider buying one of these little powerhouses. (lighter, probably stronger than 2 combined) Or are you making a 4 wheel steering?
