neweuser
neweuser's Avatar
12.10.2006, 08:33 PM
Originally Posted by Tazz
I beleave that the 60T spur gear is stock for the 18MT, because of the larger tires. 55T for the 18T and 18B. But I could be wrong. There are also 2 spur gear covers for under the chassis, one is labeled T for the 55T spur and MT for the 60T spur.
3s with the 8k motor should be fine especially if you will only be running on pavement.
I have mine setup with the rx in fron in the motor and the esc on top of the chassis brace.
That is how I have mine set up too. Works great! Just need a Lipo now and I'm set. I also think I need to re program to a softer brake...:027:
