orange00
01.08.2007, 01:03 AM
Re:Sylvester
Yes, the setup fit Stick pack Li-Po. After the test with everything ok. Will get them in mass.
Re:Mike L.
Thanks
Re fiero_silva
Don't know yet it will faster than Nitro version or not. I do this project just want to leave those Nitro maintain problem away as I'm not a frequent player. Till that moment I'm still a EP die hard fans. Just a bit worry the run time can't compare with Nitro version. And charging Li-po (especially hi cap.) will require quite sometime.
Mike.L
Mike.L's Avatar
01.08.2007, 09:17 AM
if you have a good charger anyliop battery would take the same time because your charging at 1C....
  Send a message via MSN to Mike.L
