01.17.2007, 07:46 PM
The cogging i got was vert slight, with a buggy i don't think it will be a problem. The 1940 should work better as well
01.17.2007, 08:39 PM
I experience no cogging in my maxx geared 18/66 on 4s with the 7xl.. I'm running the lowest timing also. the motor runs right around 135-140 the esc with fan 95-100 without fan around 140 ..
phil
01.17.2007, 10:02 PM
I think my cog, if it was a cog, was from running default and overgearing(20+minutes and about 173* heat might have helped) I'm going to put the timing at its lowest and work on punch control and see if it works, I may leave the 18 on to see how it works
01.18.2007, 03:16 PM
Well, i just run 5s on the Mamba Max/9XL combo. All i can say is, HOLY COW!!!! How do you guys drive it at this power level??? I couldn't run long, because my fingers got numb (a very rare cold day in the south), but the power was incredible and i couldn't keep the front tires on the ground, guess its time to find the exp controls on the nomadio. The cogging issue on 4s with the 18 tooth pinion is gone on 5s, due in part to playing with the timing and punch controls, Thanks BrianG for the advise. man this thing is nasty
Emaxx -
01.18.2007, 05:30 PM
Would this be a good setup too replace the stock 550 motors, I run for fun and use 7 cell packs and I am happy with the speed and driveability, some upgrades have been made, like cv's all around. Thanks in advance Steve.
01.18.2007, 05:32 PM
It would be a very good setup to replace the stockers!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
01.18.2007, 07:06 PM
for a stock maxx, I'd go with 4s, especially if you are satisfied with the speed. The 9XL had similar speed to the stock titansand will run with the 7 cell packs, You will need a UBEC because the internal BEC will cut out.
01.18.2007, 07:19 PM
If you think thats nasty... Try the 9xl on 6s. The motor will take it, but not the MM. I have run my 9xl in my maxx on 6s a few times and all I can say is... Silly... Just Silly.:027: But FUN! Only problem is a heavy finger means blown diffs and driveshafts.:019:
to make it...
or break it...
Silent...But Deadly
01.18.2007, 07:24 PM
Its silly sick now, that would be insane
01.18.2007, 07:38 PM
6s on 9xl is not silly power. I don't know what you guys talking about.
I thought it was just getting to the fun stage.
26 cells on a 2250 10t makes that look bad.
Peace!
Country
Help support the
Rc-Monster
Buy here
01.18.2007, 07:49 PM
6s on 9xl = silly
26 cells on a 2250 10t = Psychotic
:032:
01.18.2007, 07:58 PM
Castles web pages says the Mamba is not for use with 1/10 Monster trucks??? I realy want to go brushless but would like to make the right choice's. Steve
01.18.2007, 08:00 PM
monster trucks like e-maxx revo savage.....YOU may have mistaken it for 1/10"stadium trucks" like t4 xxxmf2.....ect....
01.18.2007, 08:19 PM
Originally Posted by Procharged5.0
6s on 9xl = silly
:032:
Leroy has a slightly skewed perspective on power. The common stuff like 6S is boreing to him.
to make it...
or break it...
Silent...But Deadly
01.18.2007, 08:21 PM
I can aspire to that! :027:
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
