MetalMan
MetalMan's Avatar
01.21.2007, 09:33 PM
The best way to get rid of your heat problem is to work with the cause, not try to alleviate the symptoms. First try messing around with the gearing, and then you should be able to find a spot where the motor runs cool, and you wouldn't need to worry about a heat problem.
