01.25.2007, 10:00 PM
@meatzardd: It should just be a redundant way to disable the built-in BEC...
Originally Posted by jhautz
I'm just not sure what it deos to ''cut off'' the power to the esc. Does it just shut it down? or just block the signal pulses from the Rx to the ESC? Does it need the red wire to do this?
I believe it either shuts the signal off or outputs a specific signal set to neutral or whatever.
