MetalMan
MetalMan's Avatar
02.12.2007, 02:25 AM
It will only pull greater than 100amps in peaks lasting maybe 1/10-1/2 sec. long, which is nothing.
The Maxamps pack should deliver twice the power, but at that point the wire/connector would be limiting the power output more than anything.
cemetery gates
02.12.2007, 07:01 PM
So, will the power difference be really noticeable between the two batts? Also will there be runtime differences?
Thanks again!
Bye:018:
jhautz
jhautz's Avatar
02.13.2007, 12:02 AM
Thanks again!
Bye:018:
You wont feel the difference. Both batteries will have more than enough power to flip your truck on command.
No doubt, the MaxAmps are based on newer technology cells. I dont own any MaxAmps, but from what I hear they are good. I can only tell you my experience with TrueRC has been as good as well and I dont think you would be disapointed.
What MM said is technically true. But IMO the differences in runtime would be negligable. I wouldnt worry about that.
to make it...
or break it...
Silent...But Deadly
